Home Park Meet Up Information
Click Here To Get Nolimits Coasters v1.8
 All Forums
 The Chuck Norris Approved AHG Topic
Note: You must be registered in order to post a reply.
To register, click here. Registration is FREE!
 Insert an Image File
Screensize:
UserName:
Password:
Format Mode:
Format: BoldItalicizedUnderlineStrikethrough Align LeftCenteredAlign Right Horizontal Rule Insert HyperlinkInsert EmailInsert Image Insert CodeInsert QuoteInsert List Insert YouTube
Callouts: Insert Speech Icon: duh! Insert Speech Icon: oops! Insert Speech Icon: sigh! Insert Speech Icon: ugh! Insert Speech Icon: wow! Insert Speech Icon: yeah! Insert Speech Icon: ok! Insert Speech Icon: yes! Insert Speech Icon: no!
Message Icon:
Message:
* HTML is OFF
* Forum Code is ON
Smilies
Angry [:(!] Approve [^] Big Smile [:D] Black Eye [B)]
Blush [:I] Clown [:o)] Cool [8D] Dead [xx(]
Disapprove [V] Eight Ball [8] Evil [}:)] Kisses [:X]
Question [?] Sad [:(] Shock [:O] Shy [8)]
Sleepy [|)] Smile [:)] Tongue [:p] Wink [;)]
 Upload/Insert an Image File
Check here to include your profile signature.
Check here to subscribe to this topic.
T O P I C    R E V I E W
Jimmy Yoshi Posted - 06/11/2006 : 7:03:47 PM
Yes, I decided to start THE Official topic on the AHG. This will be the place to ask any questions you have regarding the program, and to say or ask anything about my new tutorial which will be posted and approved soon. So, any questions?
Tutorial
AHG tool download - http://home.arcor.de/busterinwg/NL-AHG_v1_6.zip
25   L A T E S T    R E P L I E S    (Newest First)
GerstlCrazy Posted - 11/03/2012 : 8:05:57 PM
AHG will not change the banking on any track segment that you color pure black. Use this on camelback airtime hills. Color the crests, the negative g portion, pure black and their banking will remain zero.
Keep in mind you can utilize this technique to keep any banking you want on any elements, like turns and loops, etc. It doesn't necessarily have to be 0 banking either.
SupraSix Posted - 11/03/2012 : 3:31:57 PM
That is because you need to use the color coding system because ahg doesn't work with negative Gs. Go look back at the tutorial on the first page because I don't remember exactly what to do.
thisguy2486 Posted - 11/03/2012 : 2:43:53 PM
every time i try to heartline.. my camelbacks get all screwy :/. what could i be doing wrong? It is like it is trying to turn them into zero g rolls
RideWarriorNation Posted - 03/31/2012 : 9:44:45 PM
quote:
Originally posted by jdog11
Right on
A.S.C. Posted - 03/31/2012 : 9:29:42 PM
Someone's gotta kick these bots out the door.
jdog11 Posted - 03/31/2012 : 5:49:35 PM
coreyml Posted - 02/10/2010 : 10:28:45 PM
I've got green leading out of a dip and wanting the top of a camelback hill to be just a straight airtime hill. Then i have red leading into the turn at the base of the camelback hill. The segments at the top of the hill are black. Well, The track does not invert but it sways L to R with some banking before returning to the 0 banking base of the hill. it does this on TWO hills but does not do it on the other 3 hills. Anyone have any imput? I would refer to the pictures in the tutorial but ....yeah
Supercell Posted - 08/16/2009 : 5:03:40 PM
Try reinstalling it first.
Wahidre Posted - 08/16/2009 : 3:12:35 PM
I downloaded the AHG. But when i open it it doesnt run smoothly, the input feilds where you type in the values for V in and such are about an inch to the right and down, and the Load Track button doesn't work, Help please.
redgunner7 Posted - 07/02/2009 : 02:07:05 AM
wow cool#
ChrisF Posted - 06/08/2009 : 01:38:40 AM
Great tutorial! It really helped me out a lot!
SteffenK Posted - 04/06/2009 : 10:07:54 AM
Hmmm.. I've done exactly what the tutorial says (I'm trying to make a 0-G-roll), but the outcome is just one straight piece of track!
What can I possible have been doing wrong?
Vid_w Posted - 02/15/2009 : 2:30:54 PM
^Hmm, yeah, that might work...
Altho, probably not on something like a 97° drop...
More like, completely vertical.
Jimmy Yoshi Posted - 02/15/2009 : 2:24:59 PM
If you put enough filter on the past 90° segment, probably 700+, it might not twist since the filter will smooth the banking out.
Vid_w Posted - 02/15/2009 : 12:15:44 PM
^Yes, but not succesfully.
It will twist.
cooliocody12 Posted - 02/15/2009 : 12:11:38 PM
If you have a 90 degree or more than vertical drop can you ahg it?
Supercell Posted - 02/15/2009 : 10:54:05 AM
AHG actually outputs the segments like that, depending on the value of segments you put in. However, if you are using a very small amount of segments on the input track (say, one segment for every 30 feet), the track will typically not come out very well. AHG works much better when the track you put through it has a lot of smaller segments; I usually use segments from 5-10 feet long (when handbuilding) for the best results.
deek92 Posted - 02/15/2009 : 10:35:55 AM
When I download some of the coasters from the exchange it has the really small segments like in the tutorial, does the program do that for you or do you have to make the segments really small yourself, or does the heartline generator do that.
Real Posted - 12/23/2008 : 6:55:15 PM
quote:
Originally posted by DBru
A few more AHG questions...
-What is the standard heartline for an X-car coaster?
-How do I make sure the banking on the first/last segment of track is 0*? (I color it black, but the track still banks...GRR)
But if you want your precision to stay where it is, make the filter color very low - like next to black. I usually stage it. The last 2-3 segments are Black for banking and filter is like a shade of red that has a number of about 20. Then the next 3-4 are like 50. Then the next are like 70. Then my normal filter is like around 100. Some areas, higher, some lower.
hyyyper Posted - 12/23/2008 : 4:11:48 PM
1.3
Kyle Sloane Posted - 12/23/2008 : 3:33:57 PM
You need to up your precision on that part so that it follows your directions more precisely.
DBru Posted - 12/23/2008 : 02:24:57 AM
tmv8888 Posted - 08/08/2008 : 08:37:44 AM
heartline a turn with the same degree's, then flip it with purg maybe?
Vid_w Posted - 08/08/2008 : 07:09:08 AM
Nope, there's no way to heartline those...
Adrenaguy Posted - 08/08/2008 : 06:20:21 AM
yeah i have the same problem, it's a real biznatch, i found you have to ahg it yourself
You stood in queue for 0.14 seconds.
Podcasts RSS Forum RSS Follow Us On Twitter Be Our Friend On MySpace Face Us On Facebook! Watch Us On YouTube!
Snitz Forums 2000
  © 2002-2012 CoasterCrazy.com Go To Top Of Page
Six Flags Tickets | Disclaimer | Privacy Notice | Staff | Member List | Contact Form | Website Rules
