Board index Off Topic Board Off Topic Discussion Garage Door Locked, How Do I Open?
Post November 6th, 2008, 10:31 pm
Points on hand: 12,358.60 Points
Hi!
I was replacing the t-handle on a garage door and while I went to buy the replacement t-handle, someone closed the garage door. [:(!]
This is a garage door that auto locks itself when it is closed. It is a spring lock type door that when pulled down it springs the things on each side of the door and you can't pull it up. I think it's called a tension cord lock. Well, now I am outside the garage door with no way to get into it. There's the tiny windows at the top that I guess I could break and try and find something to pull the tension cord and see if I can pull it enough to release the locks but I don't want to break anything.
Do you guys know how could I go about by opening this door other than breaking of the small windows to stick something in and pull the cabling?
Thank you.
Post November 6th, 2008, 10:47 pm
Post November 6th, 2008, 10:53 pm
That wont work.
Post November 6th, 2008, 10:55 pm
Post November 6th, 2008, 11:14 pm
take the little cover thingy off the lock bolt an there oughta be some sort of manual release (like find a way to pull the bolt out of the hole in the track). then you oughta be able to push it manualy or use the cranky thing if its a automatic door.
actually i don't know.. i just made that all up,and i just realized you're outside
Post November 6th, 2008, 11:28 pm
Can you put the handle back on? Is there a square hole inside the handle mechanism that you can turn?
Post November 6th, 2008, 11:29 pm
there's no cover thingy. The thandle is in my hands which has the keyhole which i the lock. There is no manual release. It is not an electric motor garage door. It's a manual roll up door.
I think I am going to have to break the window, get a stick with hook and pull the tension cord, to which the t-handle was attachted to, and see if it will pull open the latches or whatever it is spring closing on the sides of the door.
Post November 6th, 2008, 11:30 pm
oh yeah.. duhr
get your socket set and stick a 3/8 (or what ever size the shaft onthe new handle is).extension in the hole and open the lock with your ratchet.
or like forny said, just install the new one or reinstall the old one or just stick a big flat blade screwdriver in there and twist
Post November 7th, 2008, 12:00 am
Points on hand: 935.00 Points
Maybe post a pic of the situation so everyone can fully understand what is going on?
Post November 7th, 2008, 12:06 am
I found this picture on google.
So I took out the center part which is where you stick the key in and lock the thing. When unlocked that center thing has a handle on the outside which you turn to the right, thus pulling the two cord you see in the picture to the opposite sides and pulling the latches, on the sides of the door, up, thus releasing the door and can slide the door up. With the center thing taken out, as is not, that cord is dangling further down than the hole so I can't just stick the part in and turn it. It wont catch on and turn the cord. So that's the best I can explain it.
Post November 7th, 2008, 12:24 am
right, if you took out the center part where you stuck the key in now you can stick anything you want in there and open it.
Post November 7th, 2008, 6:19 pm
Ok, so the center part is gone, so the cords are hanging loosely too far down to reach with stuff to turn it. And in order to open it, you need to turn it to pull both sides away from the center...I can't think of anything that could really do that...
Post November 7th, 2008, 6:37 pm
I had someone go out there and take off the weather stripping and do their stuff. Door is open after spending $100 [:(]
Anyone care to share the wealth? [:D]
Post November 7th, 2008, 6:42 pm
rapror you just explained the siuation AGAIN and then did nothing to help! cant you get like a hook or something to grab the cords?
Post November 7th, 2008, 7:00 pm
You should have used a bull doser. Then just stick to giant pieces of wood up for your door.
Post November 9th, 2008, 4:03 am
Chainsaw. Worked when some drunk cadillac driver roared into our garage.
Post November 9th, 2008, 4:27 am
I already payed you some cash, but if you keep spending money like this you won't get another penny from me! xD But I could give you a few pennies when we meet in knott's. [lol]
Post November 10th, 2008, 6:19 am
Post November 11th, 2008, 1:08 am
Originally posted by gouldy
yeah, buy him his hot dog [;)]
This Hotdog?
xDD
Post November 11th, 2008, 1:33 am
yay to pennies!!!! [lol]
