Board index Roller Coaster Games No Limits Coaster NO Limits editor loading two simulations.
Post September 16th, 2009, 11:21 am
When I try to go from the editor to the simulator it sometimes loads two simulations and kills my frame rates. When I try to quit the extra simulation, it gets rid of one and then my monitor goes black. I have to dirty shutdown the computer and restart. How do I fix the problem?
Post September 16th, 2009, 11:31 am
AyTrane Premium Member
You might need to reinstall NoLimits, or check your RAM for errors. Sounds like a line of code is getting scrambled somewhere in the RAM and not returning correctly. Does it do this when you open the simulator by itself?
Post September 16th, 2009, 11:32 am
Post September 16th, 2009, 11:42 am
Points on hand: 50.00 Points
Your graphics card cant handle the 2 or more Sims, it happend to me on my old PC, whenever i opened 2, i just hit Ctrl, Alt and Delete, and then stopped one of the NL processes.
Post September 16th, 2009, 11:43 am
Post September 16th, 2009, 12:18 pm
nah, my graphics card was fried, so i ended up using a broken graphics card for about 1 year, before i could save up for my gaming PC :/
Post September 16th, 2009, 4:03 pm
A7 User avatar
Points on hand: 153.00 Points
That happens to me occasionally in Vista 64-bit when I accidentally hit the simulation button twice in the editor (Razer Lachesis has sensitive buttons). However I don't get the slow FPS issues, as my rig dominates NoLimits. Its when I go to exit one, the other one freezes up the computer and monitor goes black.
So, I think we have the same issue. I've solved mine by simply taking caution when pressing the simulation button to ensure you dont hit it twice. You don't happen to have a 64-bit version of Vista do you? It seems to be the only thing on my rig that could cause a problem with anything. Someone mentioned RAM.. 6Gb triple channel 1600Mhz overclocked to 1800Mhz + tightened timings Passes 24-hour memtest86 easily. So that is not the issue in my case. CPU + GPU's are perfectly fine as well. It must be a Vista/NoLimits compatibility issue, that's basically all that is left.
Post September 16th, 2009, 6:03 pm
Post September 16th, 2009, 8:06 pm
Points on hand: 669.00 Points
Just don't click on the simulator button twice. I have this problem sometimes,too.
Post October 7th, 2009, 1:30 pm
I click once but the curser double clicks by it's self. This means I have to reset the internet box every time that I restart my computer.
Post October 7th, 2009, 2:51 pm
Well you fail then
Do it the manual way and open up NL seperatly
Rarwh
Post October 7th, 2009, 7:28 pm
If your graphics card gets fried from anything, that's because the manufacturer was too cheap to get it to cool and operate properly. I had to return a Geforce 6200 (my comp was still AGP) I got because of overheating. It had a little heatsink and nothing else to manage itself.
Do you click the jump to sim button in the editor or do you use F5? Maybe using F5 instead might solve the problem if your mouse is having issues. (I have problems on my other comp where middle clicking to close a firefox tab will close 2 instead; not sure if it's firefox or my mouse, probably the latter)
