Board index Roller Coaster Games No Limits Coaster Editing G-limits
Editing G-limits
Post September 2nd, 2007, 12:27 pm
Jer User avatar
there was a topic on here a while ago about editing the g-limits in NL to more realistic limits...how do you do it?
RIP Chiller: 1997-2008
Post September 2nd, 2007, 5:13 pm
I think 1.6 incorporated some more realistic values, but if you still want to manually define your own you can do this :
Create a .cfg file in the Nolimits directory.
Edit the file, paste these entries in and edit them accordingly.
sim.vertg.posyellowlimit = 5.0
sim.vertg.posredlimit = 6.7
sim.vertg.negyellowlimit = -1.1
sim.vertg.negredlimit = -1.8
sim.latg.yellowlimit = 1.2
sim.latg.redlimit = 1.8
sim.accg.yellowlimit = 2.0
sim.accg.redlimit = 3.0
I can't remember if you need a specific file name for it, but try something like config.cfg or nolimits.cfg to see if they work.
Post September 3rd, 2007, 1:29 pm
Jer User avatar
thanks man :)
Post September 3rd, 2007, 1:34 pm
Points on hand: 929.00 Points
Bank: 2,385.00 Points
By a cfg file, is it like a txt file or something?
Post September 3rd, 2007, 1:48 pm
Basically yeah, but with a .cfg extension instead of .txt
Post September 3rd, 2007, 2:29 pm
Post September 3rd, 2007, 2:31 pm
Points on hand: 2,204.00 Points
Post September 3rd, 2007, 2:35 pm
It somehow does not work.
This is how I did it.
First- created a new document
2nd- put in the values and changed them to my liking
3rd- saved with a cfg extension
And somehow the computer does not recognize it nor does it work in the sim.
Post September 3rd, 2007, 3:13 pm
Points on hand: 1,902.00 Points
Simply typing .cfg might not be enough... and you really shouldn't use Microsoft Office Word... Try Notepad or Wordpad (preferably Notepad) or something like that... Not a textprogram with all different styles, colors and text types. Just a basic program.
Then don't just name it .cfg but SAVE as .cfg. That is something really different for Windows.
Post September 3rd, 2007, 3:21 pm
I did use Notepad, and it only lets me save as a txt file
Post September 3rd, 2007, 3:25 pm
Post September 3rd, 2007, 3:36 pm
If you keep it as a text file you'll just end up saving it as
nolimits.cfg.txt
You need to select the 2nd option.
use the drop down, select all files, then enter in the window: nolimits.cfg
save it and now there should be a file called nolimits.cfg
Post September 3rd, 2007, 3:54 pm
Points on hand: 3,012.00 Points
In case it's on Windoze - which apparently likes to hide file extensions - after a few minutes it'll sure work out like that:
"nolimits.cfg.txt.cfg.exe.jpg.pdf.txt.txt.bak.txt"
then best send per mail and get sued for spreading a virus...
Post September 3rd, 2007, 10:09 pm
If you have file extensions hidden then you will NOT be able to - in most cases - rename a file correctly. Unhide the extensions, save as a text then "rename" file and rename it to end with .cfg. Bingo - got any problems then you are really doing something wrong.
Post September 3rd, 2007, 11:05 pm
Post September 4th, 2007, 1:38 pm
Points on hand: 3,503.00 Points
The hiding of the extension of "known types" is something that everybody should switch off permanently the oment the OS is installed (or at least now).
It is that "feature" which "helps" certain users to get infected with viruses over and over again, while other users work with windows for ten years without EVER getting a virus into the system.
"Oh, a text file, let me read it" -> clickclick -> text.txt (which of course actually is text.txt.exe, only that windows decided to cut the extension) starts up and WHAM! infected.
Post September 4th, 2007, 1:53 pm
Post September 4th, 2007, 4:12 pm
Points on hand: 136.00 Points
Originally posted by Canadmos
How do you turn off hiding the extentions?
http://www.taxinfonet.com/extentions/
You can also use the codes in the second post in a .env file to change the G-color-settings on your coaster only btw [:)]
Post September 4th, 2007, 10:55 pm
Get a nice UN*X and have fun! [:p]
