Board index Roller Coaster Games Hard Hat Area Batman The Ride: SFMM 12-20-09
Post December 9th, 2009, 8:11 pm
I am making Batman The Ride: Six Flags Magic Mountain recreation. It will be my biggest project and I will pay close attention to the smallest of things.
I need some help. Does anyone know where i may find blueprints (or something similar) of the ride? I want to make this ride as close to the real thing as possible.
Post December 9th, 2009, 8:23 pm
Points on hand: 850.00 Points
Google patents? Ill look around and PM you the things that catch my eye.
Post December 9th, 2009, 8:25 pm
please do. it would help a lot
Post December 9th, 2009, 8:26 pm
^ google patents would just have the mechanical elements such as the trains. i doubt they would have an entire layout and blueprint
Post December 9th, 2009, 8:44 pm
Points on hand: 155.00 Points
hah, one of the bolliger and mabillard documents refers to the "destruction of energy"
Kinda makes me lose a little bit of faith in whoever wrote that patent :p
Post December 9th, 2009, 8:52 pm
Points on hand: 4,770.00 Points
Post December 9th, 2009, 8:55 pm
When you slam into a set of closed B & M brakes at 65MPH, that is the destruction of energy.
Post December 9th, 2009, 9:12 pm
Post December 9th, 2009, 9:45 pm
Post December 10th, 2009, 1:23 pm
Points on hand: 3,760.00 Points
The destruction of energy? That sounds interesting, being as it's impossible [lol]
Post December 10th, 2009, 3:26 pm
Points on hand: 664.00 Points
If something is destroyed, that doesn't mean it's completely gone. It is just rendered into an essentially useless form. If you destroy a building, the materials don't just disappear.
In Google Earth, La Ronde has the closest to a direct overhead view, and Six Flags New Orleans has a very clear image for B:tR.
Post December 10th, 2009, 6:04 pm
Any information you need about the control system or ride layout let me know.
Post December 10th, 2009, 7:20 pm
Hit me up mikey. I need to know the exact height, how high the drop is, a force chart (<if you have one), loop heights, cork heights, 0-G roll height, the station buildings specs, about how long each load/unload time is. maybe more, i don't know that yet
EDIT: Does anyone have a good pic of the trains? from multiple angles (if possible)?
Post December 11th, 2009, 12:05 pm
Post December 11th, 2009, 4:03 pm
http://rcdb.com/24.htm?p=69
Dont buy starbucks coffee
its poison
Post December 11th, 2009, 8:17 pm
I have that one already. to be more specific, maybe a pic of under the trains, to the side, and up close?
Post December 11th, 2009, 9:11 pm
Post December 12th, 2009, 5:56 pm
THIS IS A LIST OF WHAT I NEED as of 12-17-09
1. lift speed
1. The distance from the bottom of the first drop to the lift hill
2. Distance / width of the loop
3. how far the first drop reaches out
1. start of lift height
2. height of the predrop
3. height of the bottom of the first drop
Post December 18th, 2009, 12:35 am
Lift speed is 3.5 in jog, and 7.1 in run. Height is 110 FT, the first loop is 96 feet, the second is 89 foot. Not sure what the zero G roll is.
The track goes out and comes back in at a weird angle to get the alignment setup for the roll and the second loop. Its at an angle so there is clearance for the helix and the roll out return.
Post December 18th, 2009, 12:52 am
Is that for SFMM?
Post December 18th, 2009, 12:54 am
That's what the SPEC is, it is not adjusted for terrain variations.
Post December 18th, 2009, 1:34 am
Thanks. that helps a lot :D
Post December 18th, 2009, 2:08 am
I'm not positive on this but I think the pre drop should be at a sloped angle of descent for momentum into the drop.
Post December 18th, 2009, 2:39 am
i dont think. the track is parrellel when it turns. its like 175 degrees maybe.
Post December 18th, 2009, 11:08 am
Just look at the google maps overhead view. The first drop definitely turns more than 180 degrees.
