Board index Roller Coaster Games Hard Hat Area B&M Floorless
B&M Floorless
Post May 20th, 2010, 6:14 am
Points on hand: 704.00 Points
You're right, the second pic is unrealistic. And while I'm at it, this doesn't look like something B&M would do either:
I know. The problem is, NoLimits is often very unrealistic. To make realisic supports I must use those track connectors or do every support as an object, then maybe we have better results. [lol]
Post May 20th, 2010, 8:40 am
By "use those track connectors" do you mean make custom supports?
Post May 20th, 2010, 8:49 am
I mean the things B&M use to connect the track with the supports, like this one:
46.72 KB
If I would build them, I would use scenery objects. But -Thrill- don't need them.
Post June 6th, 2010, 12:44 pm
Sorry for the double-positng, but I'm currently working on the station:
173.02 KB
Post June 6th, 2010, 4:54 pm
Points on hand: 535.00 Points
...Is that a sheet covering the station?
Post June 6th, 2010, 4:58 pm
It should look like a sail, the theming idea is sealing, I also will add an harbour sometime.
Post June 6th, 2010, 4:59 pm
Dude...it looks like a sheet.
I'm just sayin'.
Post June 6th, 2010, 5:29 pm
Points on hand: 232.00 Points
I think it looks good.
Post June 6th, 2010, 6:25 pm
Oh yeah... NL sucks badly at rendering B&M track nodes.
Post June 6th, 2010, 6:53 pm
Yeah you'll have to make a .3ds track connector. And as for the roof, I think it looks great. 2:1 keep it
Just keep scrolling...
Post June 6th, 2010, 11:57 pm
Points on hand: 77.00 Points
If you REALLY want to get realistic with your track connections, don't forget about those B&M Ball & Socket joints . . .
Here's an example: http://www.rcdb.com/7.htm?p=33
Post June 7th, 2010, 12:49 pm
Points on hand: 91.00 Points
Hey,
L Bosch is moddeling the objects and i show you an older screenshot, it's without any objects. ;)
Greetz Thrill
Post June 7th, 2010, 4:29 pm
Normally I would do, but Thrill doesn't want me to build them - that would take too much time, really...
Post June 9th, 2011, 2:44 pm
I'm sorry to say that L Bosch will not finish his work on this coaster. That?????????s why I am going to spend the coaster a little station, nothing too special.
Here are some pics:
When the station is finished I will upload the coaster.
mfg Thrill
Post June 9th, 2011, 3:15 pm
Looks like you need to add a "detail" layer to that terrain. Otherwise it's looking real good! Very bright and fresh.
Post June 10th, 2011, 2:48 pm
Hey,
The coaster will be named "Pelican". I added some details and added a detail layer to the terratexture.
mfg Thrill
Post June 10th, 2011, 3:32 pm
Post June 11th, 2011, 8:10 pm
Points on hand: 3,327.00 Points
lol
Post September 17th, 2011, 1:06 pm
I just playing around with sketchup and create a palm. Weeks before I made a wave in sketchup. Now I put both for fun into this coaster, take a look! ;)
mfg Thrill
Post September 17th, 2011, 3:35 pm
that wave looks epic, what happened to your other ride though?
