Board index Public Relations Post All Complaints Here underrating
underrating
Report complaints problems here with links to them. No links, no fixing them then.
Post May 4th, 2003, 12:15 pm
User 38801xlr8 rated "dueling ancients race again" http://www.coastercrazy.com/track_exchang ... sp?tid=683 WAY too low. The track did not deserve that low of a rating even for the reasons that he mentioned.
Post May 4th, 2003, 12:17 pm
wow, that is a low rating. that track was way better than he said.
Post May 4th, 2003, 12:51 pm
It is a valid rating...only if he can cover himself more.
Post May 4th, 2003, 12:52 pm
he also has a bad past history of malicious ratings... this one is inexcuseable
Post May 4th, 2003, 1:14 pm
This is true. I will forward this to the rest of the staff...
Post May 4th, 2003, 3:26 pm
I'm getting pretty fed up of this guy now. I think the rating is alright if he had explained himself more.
Post May 4th, 2003, 7:06 pm
That's what I meant about the valid rating thing. There should be a common rule, not necessarily a manditory one, but for every point you are scoring a coaster below 10, you need to add one more sentence. So, he rated it a 4, so he should have written 6 sentences criticizing the coaster and backing up his reasoning. "IT WAS ROUGH" says jack nothing. We should start offering 'rating' classes. [:p]
Post May 5th, 2003, 6:43 pm
Post May 5th, 2003, 7:22 pm
Points on hand: 4,606.00 Points
I'm not completly sure about that. I think that that thing should start at about 7. If your giving a perfect ten for something, you probably should have lots of good coments. Just saysing "this was the best coaster ever" really isn't enough.
Post May 6th, 2003, 7:54 pm
I agree about giving coasters bad ratings means more explanations, but I would also give an average coaster a 7. It takes something very special to get above that in my opinion, but I almost always point out something that needs improvement.
Post May 6th, 2003, 8:58 pm
Remember: The point of rating is to help the person out with building coasters so "PURE CRAP" is not valid.
Post May 6th, 2003, 10:26 pm
I agree. If you rate a track that you think is bad, don't just say that it as horrible, give them tips, and tell them what they did wrong and what they should improve on and stuff.
Post May 7th, 2003, 12:01 am
Post May 7th, 2003, 2:54 am
Points on hand: 3,039.00 Points
I agree with the fact that you should explain what you rated. Give tips on the problems so they can be overcome next time. I do think that that minimum line rating is kinda weird idea. I mean let people rate and we'll and the members will look after it. If something goes wrong we just warn the user and warn again or bann on a second time.
Post May 9th, 2003, 12:56 pm
[approve]
too many peeps don't give all that info tho when they rate rides.
Post May 9th, 2003, 4:33 pm
Points on hand: 12,241.60 Points
"It was rough, this track was *** oh man this track totally sucks!!!!!"
I remember that from you McFly not too long ago [;)] glad to see you've changed
Post May 9th, 2003, 5:14 pm
Post May 9th, 2003, 6:26 pm
Post May 9th, 2003, 6:55 pm
Post May 9th, 2003, 6:56 pm
Post May 9th, 2003, 7:03 pm
This was fun. Locking. If an Admin or Mod wants to open it...well...the reopen button isn't leaving. [;)]
Return to Post All Complaints Here
