Board index Roller Coaster Games No Limits Coaster Freezing building supports
Post May 20th, 2003, 8:17 pm
Points on hand: 4,955.00 Points
I am trying to finish my supports but now everytime I try to build them the game stalls and shuts down. What can be wrong?
Post May 20th, 2003, 8:22 pm
oh no[:(] happened to me twice. Couldn't do anything about it, but i do have one tip that may help. Go into a different view and try. It sucks, but it usually works. I think the problem that you are getting is "This program has performed an illegal operation and will shut down" If its that then try what I just said, because that error will not go away with that same track. Although if you started a new track, then the thing wouldn't happen anymore. It still might happen, but only on certain coasters.
-IntaminFan397
Post May 20th, 2003, 8:27 pm
Thanks. It worked and I can now build them any way. Keep posting and one day you might not be negative.LOL
Post May 20th, 2003, 8:30 pm
Since the last two days, ive posted almost 100 posts. In 2 days! Maybe even over 100!! But like my title says, I'm an ultra forum spammer. LOL[lol]
Post May 20th, 2003, 8:35 pm
Well I have a problem again. I tried doing it and it keeps freezing and the only way I can do it is the 3d way.
Post May 20th, 2003, 8:38 pm
the 3d way is the easiest for building supports IMO
Post May 20th, 2003, 8:41 pm
And you can also try this:
Save the track as an element, then open the element(track) in a DIFFERENT NL track file
I havn't tried that, but it might just work. And don't delete the original track file, just in case.[;)]
Post May 20th, 2003, 8:42 pm
Post May 20th, 2003, 8:43 pm
Post May 20th, 2003, 8:46 pm
Post May 20th, 2003, 8:49 pm
that happened to me, i just unistalled NL then reinstalled it. it happened right after i got it so the key code was still good so i didn't have to get another, that saved alot of time.
Post May 20th, 2003, 8:51 pm
Post May 20th, 2003, 8:53 pm
Post May 20th, 2003, 9:10 pm
Points on hand: 12,095.60 Points
darn, I had been working on a top secret wws track foer the past 3 weeks, no one knew about, and I just came accross this "error." Locked on adding supports, nothing complicated either, and the game crashed and stuff. Then tried to open my track and it says "could not load track"
[:(] That's three weeks of work down the chute.
WWS
My track was Hydro III just in case anyone is wondering what would take three weeks of raw track building [:(]
Points on hand: 3,980.00 Points
i think this should work, save the track file with a different name, but have the oreginal still.Then close the nl editor and open the different name file. I think it will work.
Post May 20th, 2003, 9:13 pm
If that doesn't work, then don't select all of the track element, just as much as you can for it to be savable, and name each element like: coastername1, and so on intell you get to the end of the coaster. And wws, why don't you just uninstall the game, but keep the track, then re-install. That might work, but I don't know.
Post May 20th, 2003, 9:20 pm
WWS
thats what happened on my twisted perception, i had to recreate it all, it sux really bad.
Post May 20th, 2003, 9:34 pm
that happened to one of me woodies. I just cancelled building it.
Post May 22nd, 2003, 12:12 pm
Hi this has been happening to me to and it is really anoying me, because every time i build a support the game crashes.I cant build a coaster without the game crashing at least once.Any tips that will stop this happening i will be very gratefull for.
Post May 22nd, 2003, 4:45 pm
yes, build the supports in a different view, or save the track in a different file.
Post May 22nd, 2003, 6:47 pm
Points on hand: 2,992.00 Points
Has anyone tried updating video drivers? This sounds like the kind of thing a screwed up driver would cause. Or how about running the editor in software mode? I don't know how NL's editor runs, but I assume it uses OpenGL which some companies (ahem, ATI) don't run very well. This is just an idea.
Post May 22nd, 2003, 7:08 pm
I was building a coaster and all of a sudden my OpenGL closed and I lost everything. Happens quite often too. [}:)]
Post May 24th, 2003, 8:22 am
Post May 25th, 2003, 2:08 pm
Points on hand: 2,897.00 Points
I have this tissue too, My suggestion is do the track part first. then save it, and begin on custome support building, save every 1 min or so, that way you don't have to do alot of works when the file is closed by error.
maybe we should ask development team about this?. what you think?
Picard
Post May 25th, 2003, 2:14 pm
Is it even an error that the development team can fix? If so, yes. And I usually save my tracks after doing one tube, Then I save, then I do another tube, then I save, and etc. I don't know why I even do this but if I make my track real good, even if its just one little thing, I can't afford to lose it, because I can usually never make it as good as the original thing that It was.
