Board index Theme Park Discussions Theme Park News & Construction! Lightning Run at Kentucky Kingdom Going Up Fast
Points on hand: 11,572.60 Points
Kentucky Kingdom has started to share photos of their new roller coaster, Lightning Run, being built at the park. A few days ago they shared the image above, which shows some of the coaster's taller supports standing in place. I can't be sure, but I think that the supports shown here are for the coaster's second hill.
Today the park shared another image, and this time it shows that some track is also already in place! The outside curve seen here is the one that takes place at the bottom of the first drop, you can also see another curve in place behind it for much later in the ride's course. The curves are very tight, just like in the concept art - this should be a very thrilling ride when completed.
Just as a refresher, here is a shot of Lightning Run's full layout. The section being worked on now is in the lower left corner, immediately following the first plunge.
Original Article at NewsPlusNotes By MikeH
Points on hand: 15,383.90 Points
Maybe that's why they call it 'Lightning' Run, referring to the coaster's speed as well as the construction time table.
That's the right corner Oscar. I thought this ride would suck at first but then I learned Chance Morgan didn't make the layout, so that is a definite plus as the only worthwhile ride they've ever made is Phantom's Revenge
Points on hand: 4,657.00 Points
Has the layout changed or has it been so long since I've looked that it looks different
Points on hand: 28,053.00 Points
Layout looks pretty good to be fair , fairly intense i should imagine!
Points on hand: 13,491.00 Points
Looking at how steep the first drop is, I bet this coaster will be pretty thrilling. Just like Intamin Mega Lite is a great example of thrill you can't judge from the size! :D
The layout/shaping is designed by the guys who do the RMC coasters. This will be a badass ride.
^How? So the only thing chance Morgan did was fabricate the track and supports..
Also has anyone seen the hot trains?
Designers are often separate contractors/consultants to the company that actually manufacture the track.
For example John Wardley (Nemesis etc) and Werner Stengal of Stengal Engineering (Millennium Force, Mystery Mine) are designers who work with various manufacturers (B&M, Intamin, Gerstlauer)
It's very possible, the trains are also based on those on the RMC woodens.
Anyone know if they're getting new trains or anything for the SLC they insist on keeping?
Points on hand: 3,322.00 Points
probably not this year
SLC is getting new trains and to open in 2015.
And yes, Ride Centerline LLC is the company that does designs for RMC and now this coaster.
Update!
The first ride on Lightning Run occurred just a few days ago!
I think it looks to be the coaster equivalent of that geeky kid that you pick on, only to find yourself on the receiving end when you learn the hard way that said geeky kid has a black belt in Tae Kwon Do.
MY BODY IS EFFING READY!
Points on hand: 5,506.00 Points
Oh my god those ejector hills
Yeah looks pretty crazy actually! Doesn't waste time getting up the lift hill either!
Not at all! That thing is flying for a chain lift.
That ending is fantastic.
Points on hand: 5,889.00 Points
SkyArrow wrote:
I've seen others describe it as a steel RMC.
That's because it basically is... the track layout was designed by the same company that does RMC's layouts... I think it's called "Centerline Rides" or something.
RMC makes extreme Gemini's lol.
I agree!
I think that's quite an acceptable way to describe it.
