Some interesting things to consider:
1). The Rocket Coaster is happening in 2006, confirmed to 235 Club by a senior person at BPB Ltd.
2). They said it would go from the Millennium Bug Dome (the ride was removed this year in preparation) and go out to the sea.
3). The 3 footers are very similar to the ones at Cedar Point, albeit bigger and reversed, (probably due to the stronger winds and more unstable ground).
4). There is only one place that the rocket coaster track could pass through the big one - where the two hills are adjacent.
5). The 3 footers are not only perfectly in the right place for that, but they are also aligned just right with Watson Road (even at the exact angle) so the track would head off to the Millennium Bug Dome.
Those of you with a keen eye may notice that the footers are reversed from the Cedar Point versions.  This could be due to the strong winds that would batter the ride from the Irish Sea - hence putting the single support on the park side of the structure to help counter the force of the wind.
i copied this from the site...
so i guess it would be true...
